TYTILIDIE
METH HEAD
So as I stated in the other post iM gonna start from the top.
When I first got my engine running I fired it up on the stock chip. After running it for a half hour, I put in my Ultimate and 3 BAR MAP. I broke it in on the T1 15 PSI setting. I think I had my FP @ 40. After a few hundred miles, I started to turn up the boost. Immediately I had stuttering problems. After talking with Austin (16SY16), I decided to lower the gap on my spark plugs. This made a huge difference and allowed me to run the boost I wanted. I then started leaning out so I went to tune one day and ended up with FP @ 50(VAC line on). Now I was on T1 18 PSI setting but had the boost controller set at 17psi. My truck ran great and 02's were at 930ish at the top of the runs. I use Datamaster BTW. So after a few weeks the truck was still runnning great. I decided to turn it up to 19 Psi. So I go tuning and put the Ult at T1 20 PSI. I put the boost controller up to 19 psi. I was leaning out but after a few adjustments to the FP, finally set to almost 60(VAC line on ) , my 02's were at a 920, had 150 IAT's and 4* KR at the top of a run. I was very happy with the way it ran. I had it like that for a couple weeks and then one day, I lost fuel and broke down. I limped the truck to my sisters house where I worked on it and found out the fuel line going from the pump to the metal line inside the tank had fallen apart again. So i fixed the hose again and fired it up. It would seem to turn over a long time before starting. Also, it would only run for about a minute before blowing the ECMB fuse. I hotwired the pump til I got home and put a bigger fuse in it. Havent had it pop yet. At this point, I could not get the truck to go back into a decent tune. Basically, when I would start the truck, it would load up with fuel really bad. After getting on it once or twice itld be ok. Sometimes it run good in the top end and other times it would stumble and fall on its face. No tach flutter. Sometimes I can drive out of the stumble. Turned the boost to 0 and still had this problem. I did notice the more I would drive the worse it got. I did change out the filter when I fixed the hose. So anyway. I started to try everything, turning to different programs, FP's, boost levels. Nothing works. It grew a mind of its own. As it got worse my DM would say at WOT 02's were low in the 1-200's. I stopped and decided to put the stock chip back in just to see what would happen. So I did this and it was fine. I did have a dead spot and the boost would pull me out of it. As if it was somewhat flooded. So I played with the FP and got it to run pretty good. 02's up 850-90's at the top of my runs at 15 psi. So for shits and giggles, I put the stock regulator back in and it ran even better. Fp Checked out to 37 (VAC line on). Heres the wierd part, I noticed with my AFPR, the higher I set the FP, the needle would go haywire. The lower it would steady out. Also, I would snap the throttle and FP would go down slightly. With the stock reg, it responded perfect going up when the throttle was snapped.
Now for the Voltage issue. At the top of the runs with the Ultimate, I had 11.5 Volts. ABout 13 at idle. With the stock chip, I had 12.1 at the top of a run and 13at idle. I checked Voltage at idle with my voltmeter and it said 14.5, DM said 13.1. I took it to Autozone and they said it checked out perfect.
I decided to test the Ultimate in another truck. Now I couldnt get my laptop to hook up but we noticed a hell of a difference right off the bat. And yes we did put the 3BAR MAP in. I didnt wnat to put in the AFPR so I didnt take it over T1 17PSI. When we did try it though, it was amazing wqhat a difference it made. I scrolled through every program and it never stalled the truck like it would mine. So IM positive the chip is just fone. I put it back in my truck and could bearly get the thing to run. So in short, I had to go back to the stock chip.
Well, that s it I think, if anyone has any ideas let me know. My mods are in my sig.
