SeattleSy#1255
Category 5 Conservative
Please allow me some slack as i'm still learning...and what a vehicle to learn on.....
my question relates to the dis. cap...inside/underneath the brass terminals are somewhat corroded. I know that its normal after some time, but what I am finding is that the corrosion is taking place on one side of each terminal (same side)...meaning its apparent which way the rotor is spinning because the corrosion is only on one side of the terminals. I was wondering if this could be an indication that timing is off and its spark is occuring at the edge of the terminal rather than the center, or does it matter?
only other things a novice like me can come up with, is that the rotor was on wrong, which seem near impossble as its only goes on one way (its either on or not on) .................... or that the metal piece on rotor was to long, but wouldn't make sense because it would show a scrape the full length of the termals on the cap, which isn't occuring (its only on one side)...
of course the best way to check timing is to have it timed...i know that i'm just curious if this is an indication of anything at all?
everything is good stuff, conrad cap/rotor, taylor wires, ngk's etc....
hope that isn't to confusing, but the only way i learn is to get dirty and ask stupid questions.
TIA
TIA
