Carbon Poly Dist Gear
Larry
Carbon poly dist gear
Yep, I have had one in my chevelle for a while now. Seems to work fine so far. If it makes you feel any better, Nascar has been using them for years so I figure they have proven themselves somewhat. Larry.
ed hess
race or get outta the way
jimmy
i got one. had the dist out a couple times since and no wear at all!
do it!
ed
Larry
If I remember correctly mine set me back about $120 which is 4 times as much as the cheaper brass gear. And if you run a roller which I have 2 hydraulic rollers in 2 different cars of mine, you have to have the brass gear or the nylon. The camshaft is ground from a hard steel, not cast iron like a typical flat tappet cam, and it will eat on a stock distributor gear. I do know that comp cams now makes rollers with a softer distributor drive gear on it so the gear change on the distributor is not necessary. I believe that is the only cam company doing that so far, but I am sure others will follow. Larry.
Sorry Larry, you're wrong. Don't need any high tech bronze or carbon dist gear on a hydraulic roller cam. I have two cars with more than 580 lift with Hydro cams. Don't waste your money on it unless you already have the bowtie heads/block and 91mm...or if you're rich like Ed Hess and have everthing you could possibly cram into a Syclone. :wink:
jwaller
Evil Genius/SyTy Guru
dittto. the hydro rollers made today don't require a special dist gear.
Larry
I guess you guys are talking about the v-6's, don't know why they would be any different, both of my hydraulic rollers are in big block chevys and yes the cam manufacturer told me they both needed bronze gears, I didn't argue. As far as my ty goes, it's all factory and never been apart, maybe the factory does something different there, I don't know. Larry.
aftermarket hyd rollers are fully steel billet.
oem's have a cast iron gear added at time of manufacture.
replacement rollers for oem equipped roller engines share this characteristic, so no need for any exotic gears on the distributor.
that said, teh plastic gear 8WILL8 eventually give up, so have a look at it every so often.
we've used a bunch with great success where needed.
hi john.
