ceramic coated main/rod bearings
G
Guest
Guest
It seems like the latest craze is "ceramic" coatings..... pistons, cam bearings, etc... Anyone know of sbc bearings that are ceramic coated, and where to find them? New motor is getting ceramic coated cam bearings (readily available) and was curious if someone had some main and rod bearing ceramic coated sets available?
Last but not least, is it really worth the effort? <----- I dunno
G
Guest
Guest
Geeez, I'm beginning to feel sorry that I asked... :)
"Thank you for the e-mail.
Let's start with DL-5----this is a Military dryfilm that goes on most of the
Fighters jets and ballistic missiles for it's low friction.
There are 4 types of coatings.
1) Dry Film for lubrication, inhibits galling, and will enhance heat
dispersment.
2) Thermal barrier coatings for reducing the movement of heat.
3) Thermal dispersents, for moving heat to a location
4) Corrosion and chemical inhabitants, for retaining material life.
5) Diamond like coatings----This is a game out in the market, we now have in
the world 10 companies who claim they have a diamond like coating or Thin
Film. The only real one that blows the others away with real testing is
Casidium.
We now offer that.
Example: Titanium retainer set--$ 330.00 not cheap but the most effective
thin film in the world hands down.
Wrist pins $ 330.00 set unscratchable
Valves $ 330.00 set longer lasting better sealing and heat resistant.
Why the same cost? Good question. Because we have to use a batch in the
same chamber over and over again.
I am know working on prototyping cranks.
Now what's your question after all this and where would you like to start
Roland?
Respectfully: Gregg Hekimian"
4C FED
Absolutum Dominium
Yes, Gregg is quite lively.
The only drawback with him Roland, is he only takes cash/check/MO.
He does not accept any kind of plastic.
We do a TON of dry film lube at work. I can probably get you good deal on that, if you want the dry film route.
We also did some testing with a place call armaloe (probably spelled wrong). It also looks good, has good friction charactaristics and heat.
I can dig up # for them, they might be worth calling. They did some prototype pieces for us, for fairly cheap I believe. I can find out more.
You know how to reach me if your interested.
G
Guest
Guest
Thanks again Rick....... I do believe we're narrowing this down a bit 8)
Now I've gone and asked him about Cryogenics versus nitriding of crankshafts......... some of us just never learn!
"Hi Roland:
Sorry for the confusion.
Yes, the DL-5 would be best for your rod and main bearings. as well as
Cryogenics. They compliment each other.
Gregg"
G
Guest
Guest
Thanks to you also Jeff.....
So far I fiqure it's ~$100 plus the cost of main/rod bearings for the DL-5 and Cryo treatment. For $100 +, I'd try it. I also need to do something with the stock crank (last Nitrided one got slightly eaten up), so either Nitriding or Cryogenic treatment.
Personal opinion, but if someone came up with a forged even fire 4.3L crank @ $1200 apiece........ I think they'd sell lots! Jeff: will that CNC machine of yours laser one out for us? :wink:
G
Guest
Guest
I swear, the more I "think" I know the more I get confused.
"Glad to assist you.
Nitride makes the crank better and Cryogenics after the nitride eliminates
the stress risers.
So what ever you do Cryogenics only add to it.
Nitriding actually causes more stress risers because when it cools it
fractures and the cryogenics removes the fractures.
Cryogenics is not a substitute just an enhancer.
Cryogenics stress relieves, makes the metal more durable, and creates a high wear resistance.
So I would do both.
Hope I have been helpful.
Gregg"
