changing elec fan/ic pump ecu constants
cvcsmkr
i have a variable speed controller on my volvo fan.
i am using the ic pump wire(orange) to signal the fan.
i want the signal to the fan to cut out as soon as igniton is turned off.
i found these 2 constants.
max time on after ignition off
min time on after ignition off
what should i set these at?
is there anything else i should change in the settings?
thanks in advance
