tbauer03
TRBOBOX
Three things happened before this started.
1) I was moving wires around the fuse block between my switched ign outlets and the lamp switched outlet to do some troubleshooting with my Holley Dominator.
2) My 2 year old daughter was playing with every switch, button and/or lever around the dash and steering column while really enjoying the horn.
3) I started the truck let it run and then shut it down
Then with the key in the off position the audible warning chime like the headlights have been left on and the check gauges light faintly started to blink .
The only way I can kill the warning chime is too pull the hazard/light fuse but even then the check gauges light gives a faint pulse and over time depleted the battery.
I didn't notice anything obvious like lights being left on and I started pulling fuses one at a time but couldn't figure out.
Any ideas?
Thanks
Any ideas?
Thanks
