Check out my pushlock vacuum lines
TYTILIDIE
METH HEAD
Just thought I would show everyone the vacuum line set up I put on the wife;s Ty. I have the same type stuff on my Ty but mine are black fittings with red stripes.
TYTILIDIE
METH HEAD
Re: Check out my pushlock vacuum lines
It isn't a kit. I made all this myself. Of course I found a source for the fittings. If you look around they are all out there. I did this for less than $40.
Bustedsm
Numbered Car Crazy
Some of them are rated pretty highly. Can't find the picture I was looking for, but it was on some big blocked, huge twin turbo'd buick....not sure though.
QuinnSY
We use thoes push in style conectors all the time at work for neumatic stuff. I have never seen one leak or break loose and we are using much higher pressures. We have also never used them in high temp situations though. Good idea, I might have to give that a try!
Houseofperformance
switchhappy!!!
if the lines are nylon there will be no temp issues - wouldn´t use the polyurethane ones.
easy to tell the difference: the nylon ones are relativly rigid and will kink if bended too much, the poly ones are more flexible but are heat sensitive.
