Check Valve in fuel pump
Jimmy
Banned
A truck I looked at appears to have a bad check valve in the fuel pump.How do you fix it?
skata
Re: Check Valve in fuel pump
you know when i first got my truck, the fuel pressure would always drop after the ignition was shut off. this is a walbro pump. when i finally got to taking the pump out, i noticed the check valve came off the end of the fuel pump and was lodged sideways in that little hose between pump and sending unit.
i popped it back on the pump and now i make sure i add a third clamp to that little hose. put it right after the check valve but not too tight, just enough to prevent the valve from popping off.
the valve is kinda just pressed on, not a real good design. so add the extra clamp to make sure it dont come off.
Sometimes, it comes off in the rubber cover the Walbro come in.
Or some times when you pull the rubber cover it pops out and fails the storn drain :rant: I drove my truck around for a few months before I ended up replacing the check valve, it didn't seem to affect the way my truck ran except for waiting for fuel pressue to build up before attempting to start the truck.
