cheatham2492
I had a coolant leak for ever.It would only expose it self when I got over 18-24psi of boost.I replaced the head gaskets and got my heads completely redone. 1000.00. Prolly the 2nd or third time the heads have been touched.The valves moved over an inch back and forth when they came out of the head.The Machine shop milled a little metal off to resurface them etc.I put the heads back on with new gaskets,ARP hardware. Torqued them to 70Flb. Filled it with oil and coolant. Came back the next day to start it.I ,pulled the rad cap off to add more coolant and I could hear coolant pouring out of the block.... ^%$^%$^$&^$!!! It was pouring right out from under the gasket/head on the back passenger side. Same place it was seeping from for years.
So I thought the only thing that could keep the head from sealing was the Dowl pins in the block .I took it all down again.Scraped the gasket off and set the head back on.The head would rock on top of the engine. So I wacked the dowl pins with a sledge hammer a few times and set the head back on no more rocking or wiggle..I took the other side off and the dowl pins/heads were the same.So wacked them till the head sat on flat and straight.
When they resurfaced the head again.Machine shop took off just enough metal to expose the problem.The dowl pin holes are deep not sure why that happened.Could be the angle of the dowl pin digging in to the head.Dont know.I used a victor reinz head gasket.
I am feeling confident that the head will seal completely. Coolant passages and cylinder area.
Check your head next time to see if it still sets properly on the block.
D.Cheatham
D.Cheatham
