CheckBALLS
Foot Performance
i thought i have read that some one said you could leave certain checkballs or a checkball out to improve maybe to have full pressure on two diffrent clutches i have looked threw my hydrolic charts and cant find one that i would leave out and i am pritty sure that most are diffrent but i think they have the same number if there are some give me the number so i can check it out thanks
i have done some searching and cant find anything.
the trans is out of a 94 camaro
jwaller
Evil Genius/SyTy Guru
Re: CheckBALLS
you can leave out the one in the rear of the case and the large copper ball that is supposed to help if you have not hooked up your TV cable but they arent going to boost line pressure or anything lik eit. the rear case ball will give you a harder R engagement.
Foot Performance
Re: CheckBALLS
o ok that one just by passes the small port and lets a lot more fluid to it but i dont think i will be doing 60mph in reverse so i will probably just leavem like i foundm
