MyTy
Hey everyone here are the specs i got when i purchased the Ty..
Engine block was bored .030” over stock. Crank was turned and balanced, JE forged pistons fitted. King racing bearings are oiled by high volume melling oil pump. KB roller cam shaft with 205 degree sprongs and retainer keep valves seated. Cylender heads had 2.02” intake valves and bronze valve guides installed. Heads and intake were also ported and flowed. A larger turbo with 650 cfm replaces the stock 550 cfm flow turbo. Throttle body air foil installed, also increase air flow. Stock air cleaner is replaced with cool air fender kit. Under drive pulley set reduces pulley speed by 25%. Fuel pressure is increased using external high flow pressure electric pump. Fuel pressure is increased by adjustable pressure regulator. KenneBell street master chip controls 40lb fuel injectors. Intercooler pump can now be set to run full time using a switch on the dash. Transmission governor was replaced to make full throttle shifts at 5000 rpm instead of 3800rpm. Torque converter lock up can now be controlled by switch on dash. Distributor module was upgraded to an accel race module. Stock plug wires replaced with red jacket turbo wires. Exhaust changes are from catalytic converter back using Borla stainless muffler in to dual stainless 2 ¼” tail pipes.
I have three Questions..
1. I want to replace the KB chip. What chip would go well with my setup..Keep in mind I'm willing to switch out the 40lb injectors for bigger ones if that's what people suggest.
2. Fuel Injectors... Should i switch to bigger ones?
3. What fuel pump would be good for the future setup of new chip and possible injectors?
If you don't mind would you please post where i can purchase the parts that any of you recommend. Thank you very much for your time and suggestions.
