Chip install help
bshaw1979
So i got my turbo tweak chip in the mail today and went to install it.. I open the access cover in the ecm and i see that it has an older pit bull chip. Now this might be a dumb question but do i need to get a stock chip so i can then install my new turbo tweak chip onto that? Thanks for help in advance.
13Pelle
Re: Chip install help
Yes, you need to pull the ATR chip out first. Should piggy back on the Turbo Tweak one.
13Pelle
It will piggy back like this setup for Code59
bshaw1979
ok i have it piggybacked like you said. The brown portion of it has has the sticker on it that says pit bull on it. I just wasn't sure if the turbo tweak could piggyback the pit bull. Is this right?
5678TA
looks like how i did mine. ATR Pitbull piggybacking the TurboTweak here as well.
Eric Sy GN
Any memcal that has the original Syty knock control circuitry will work. You can tell by the part # on the little circuit board. The 2nd and 3rd digit will be "14". (At least from the research I've done.)
The actual eprom chip (Pitbull, KB, etc), doesn't matter at all, since it is being bypassed completely.
