chip observations / board feedback
Gnocide
turbo game burt reynolds
my stock inj 92 ty, chip id is 0 (saudi maybe?)why might i say that? at the northeast syty gathering using datamaster and snapon scantools show some weird stuff. such as it runs open loop all the time(can i run leaded gas without an o2?). 02 voltage stays less then 60 mil volts at idle then richens up under wot.at the extravaganza don and morgan said the o2 was bad but no code.changed the o2 and same result. almost perfect fuel curve.tps is .66 at idle and 4.20 wot.iac is 26 @ idle. spark advance is 18 @ at idle. no egr call, temps do not exceed 105 mat. any thoughts and comments about this?
InvisiBill
http://www.syty.org/old/promguide.html says 0 is the Saudi chip. Those ran leaded fuel so the O2 sensor stuff was removed. http://www.syty.org/old/saudisy.html has more info on the chip differences, including the removal of ESC trouble code. It also says that knock retard is set to 0&#176:, which isn't good. "What this means is that the engine could be knocking worse than a flock of woodpeckers but the ECM is unable to do anything about it."
You should get a regular stock MEMCAL in there ASAP...
Gnocide
well i dont throw any trouble codes and the knock is registering about 3 deg at worst. as for safty against knock and power i have the j&s safegaurd so im fine there. i mean the truck runs good, 13.6 at 99 on 92-93 gas.thanks for the info on the chip, ill do more research.
93ty475
gnocide,
how's it going? did you figure out the j&s ? i hope so...
i still have the msd if you decide you need it...
InvisiBill
Well, that link says some weird things. Like the US chip has a fixed 3° knock retard and the Saudi has 0°. I don't know if this is some initial response as soon as knock is detected or what, since I'm pretty sure US chips don't have KR fixed at 3° constantly... Maybe this page was written based on prototype info or something?
Anyway, the chip has some weird differences compared to a US one, including some sort of KR modifications. Personally, I just couldn't trust it... I'd at least have to find a US chip and try it, and make sure there wasn't some big issue going unnoticed.
Also, the timing was changed in the Saudi chips for use with leaded fuel. With an unleaded calibration, your truck might even be faster.
Gnocide
93ty475 said:
gnocide,
figured it out thanks and i called john at j&s was very helpful. i have to figure out my chip before i make another mod though.servando ill keep you in mind and thanks again.
