Chip Questions. Please Help.
Syclone#1992
SyTy.net Moderator
Ok here it goes.
I have an ATR Chip that I would like to better understand. What does this chip do that the stock can't? I think it raises the rev limiter. Does this chip still have stock boost levels? If I decided to upgrade is there anything different than the Ultimate? I really don't want to fool with the ECM.
I would also like to know the different methods to control boost (raise and lower) Can this be achieved with the current chip?
Thanks for the help. No flames please, I am just trying to learn :smile: .
jwaller
Evil Genius/SyTy Guru
http://www.syty.org/old/promguide.html
this will show you what the ATR and other can and dont do for ya....and no the ATR will not raise your boost level BC the stock map sensor is nearly maxed out with the stock chip....to PROPERLY run more boost a 3bar setup has to be utilized
AXXE
If you are trying small steps and learning like I am, the Ultimate is the way to go. It give you so many choices it is unbelievable.
Saudi Sy
I have a brand new Ultimate chip that I might be selling. Any interest in that???
Bob Bertermann
Saudi Sy #2734
Syclone#1992
SyTy.net Moderator
Sorry Bob not at this point in the game. I am just trying to get a well tuned truck with all the safety or "minor" go fast mods. The question for me is do I want to go farther modding or leave it pretty well stock. When I get done I will have to make a decision whether I want to do the fuel pump and chip as that would be the next logical step.
Right now I have an ATR Exhuast, Cold Air kit, Chip, Soon to be Hotwired IC, and possibly a high flow cat. Right away in the Spring I will hook up Datamaster and fine tune before I do the fuel pump or chip.
There was a person at the Michigan meet who had a chip where there were different settings,one for the strip and one for just a tad higher for street racing, and then one setting where you could accually turn the boost up manually through the chip in the truck. I believe he had Scott "Dig" Bartho-something or other chip. It sound like a good setup. Is the ultimate like this?
Saudi Sy
The Ultimate has MANY different settings. You can adjust the psi on different fuel settings. I believe you may even be able to go up to 24 psi on race fuel with the ultimate chip. All you need is the AFPR, pump chip and the 3 bar MAP sensor. I have basically the same mods that you have right now. I would definitely do the pump. It isn't really hard to do it in the Syclone. I had taken off the bed to do this. I found this easier because you don't have to run your truck low on gas and drop the tank. It is even nice to be able to clean up the rear of the truck while you got the bed off. Email me in private if you have anymore questions.
Bob Bertermann
Saudi Sy #2734
saudisy@wi.net
