Re: chip questions?
crusader8 said:
im finally modding the ty, and from what i hear the 3bar ultimate is the best
what is the difference between the 50#Ver2 and the regular 3bar ultimate
what are the mods to do with the ultimate?i plan on fuel pump/afpr/IC pump/boost gauge.
I assume i can get all of this from ARAUTOSPORTS?
Get a boost gauge first, as the stocker varies quite a bit. It's nice to know exactly what's going on even with a stock truck.
Get the Walbro next. This will ensure that your FPR always has enough fuel to give to the engine. Might want to do the Racetronix (or your own) relay harness to provide the pump with more power as well as reducing the load on the stock wiring.
Get an AFPR and gauge. This will allow you to do a bit of tweaking through the fuel pressure.
Get a Jabsco or Sureflo if you need it. There are several people who have stock IC pumps still working great. I honestly wouldn't worry about it unless the stocker's dead or your IC temps are insanely high, indicating some sort of problem.
