Chip replacement with Ultimate hardware
Maxtor
For those of you using the Ultimate harware and doing your own chip tuning; are there any options for the chip socket to make changes easier? Seating new chips in the original Ultimate carrier is very time consuming. Any help would be appreciated.
Thanks.
smeagol
You can stuff a ZIF socket into the soldered socket on the circuit board.
Gotta be careful though, since vibration and such can pop the ZIF free... don't ask me how I know. 19 sec ET ownz me.
It can make the memcal fit weird, might have to scratch putting a cover on the ECM as well. If you put the ECM in the glovebox though, it should be fine in this configuration.
Sy#26
You can remount the ECM so's the chip carrier is accessable and use a ZIF socket in the carrier. Loosening of the chip *is* a problem; I made a 'C-clamp' spring loaded thingy out of 1/2" strap iron, 1/4" rod, a spring & a knob from RatShack. Keeps things nice 'n snug, no more probs.
Daron
I just use a chip extractor when removing. These keep the pins straight. Straight pins make seating easy.
Sy769
Glove compartment ECM is nice.
Bent prom pins ownz me. :x
Ty1450 will let me race,modify,abuse his truck but I am banned from touching the prom. :p
I like the Lever style Ziffy thingys.
Maxtor
Thanks for the suggestions. It seems like new chips come spread out a little bit, that's the problem I ran into last weekend. I bought a few spares since I was placing an order with JDR and their S/H is about the same with one item or twenty.
Barry - You amaze me. Is there anything you haven't thought of and engineered your own solution for? I spent at least five minutes trying to visualize the "c-clamp thingy" :D Sounds like a great idea, I've got one of those mini-vises for PC boards......
sytyguy
Moderated User
I use an extraction tool when removing to keep the pins straight as Daron mentioned. To install, I seat one side of of the prom (rock the prom to one side) and use a hard flat something (credit card, license plate, ninja star, whatever......) and push all the pins at once to seat the other side. Has worked flawlessly for the last 4 years and not one junked prom from bent pins.
Hood
ty1548
If you ever come up with a final set of programs and the original Ultimate nomenclature no longer applies, I can reprogram the display chip to whatever you want it to read, and it can have anywhere from 1-16 settings. In other words, if you decide on only 12 settings for example, the chip can be reprogrammed to display and address only 12 programs.
