chip tuning
E-Rue
generally speaking..... on L35 heads, is 22~23 deg of spark advance a lot at 8psi of boost?
i was scrolling thru my datamaster run from last night, and was noting how the KR started at about 8psi. at this point, datamaster claimed the ECM was commanding 22~23 deg of spark advance. this is a chip program that i dont know much about, so i thought id ask if it was way out of line before i started modifying it.
e
sytyguy
Moderated User
Might be a little high. Mine's around 20 deg at 8 psi, but only drops 1 deg up to 16 psi. No knock and works well. Course, your build is a little more aggressive than mine. For you, does it just knock at that point and stop after timing backs off a little with more boost? or does it start to knock there and continue to knock? What's the timing at full boost (16-18 psi)?
You have the run handy? If so, zap it to me and I'll have a look.
FWIW, I tend to run 18-19 deg @ WOT on pump gas and 20-22 @ WOT on 100LL. Has worked out well thus far. All runs have been with low boost (16 psi), so I'll have trim it back with higher boost.
Michael
E-Rue
yeah ive got the run handy, its on my web page. its really just a long recording of me driving around, for the first time after the cam install. i will go ahead and tell you that i was looking at the computer when i was testing it out, so as soon as it hit KR, i let out of it, so it may not tell you what you want to know.
another question.... would the amount of advance ground into the cam also affect total advance?
ECM commanded advance + ground in advance = total advance?
if so, i better call jerry and find out a little more about this cam. it doesnt sound like the tune is too far off, by what your telling me.
keep in mind to, that this is gonna be a street program for me, so it needs to work great on 93octane. you didnt really make any reference to what kinda gas you were runnin with your tune.
thanks for the help.
e
Sy769
The advance ground into the cam really makes no difference to your timing.
When you set your base timing what are you setting it relative to????
I thought so :wink:
B
Blake
Guest
Sy 769,
I'm not sure I understand what your saying. I'm thinking like E. When I called CompCams about a year ago and asked them how much advanced the cam was ground(can't remember exactly which one, it's been a while), the guy was like "it's advanced about 5 degrees." I asked "about??". He said they couldn't tell for sure. I was confused with that and thought maybe the tech I was talking to didn't know what the hell he was talking about.
That left me with...if a cam is ground 5 degrees advanced with the dots aligned, then I would need to either retard mechanical timing 5 degrees or go into Promgrammer and start hacking away. Or do it right and get a degree wheel and install it correctly according to the cam design and not just align the dots. Is that right? Seems like you would want to keep your base timing at true zero and then chip from there. Any help is appreciated. Unless, of course, your just dicking with E :wink: Then just consider me a retard :p
Blake
smeagol
He's just saying that timing advance is relative to crank position (TDC really, but based on crank position). You can have the cam degreed any amount, but since your timing is set based on crank, it won't matter.
valvetrain events are independent of ignition events. You can set the cam to open the valves whenever, but as long as you set the distributor based on TDC (piston stop/timing gun etc), it won't matter what you do to the cam. Cam is set referenced to crank as well, right ? ;)
Damnit e, you had to ask a retarded question to cornfuse people :drinking:
CLONE
The distributor gear on the camshaft just drives the distributor. You can install the distributor 180 degrees off, but as long as you twist the body back around relative to the rotor which stays fixed to a location based upon the distributor gear, it'll run fine. I've worked on a truck which GM did this to when they swapped a blown motor under warranty.
The advance that E's referring to is valvetrain advance only in our application.
He asks this question here, yet when he asks me something on AIM, it's always about some big black booty or something like that.
E-Rue
i see now.
it makes since when you break it down like the beastie boys.
cam advance and ignition advance cannot be added together because they are both set in relation to the crank, and not each other. i guess the ignition would have to be set in relation to the cam in order for the cam advance to make any difference in total timing.
ahhhhh says the grasshopper.
by the way..... josh you find me any thick bottomed chocolate booty up there yet?
e
Buster
Re: chip tuning
e
The extra advance at low pressure is in there for a reason and shouldn't cause crazy knock. The timing helps make up for the weaker bottom end, the bigger turbo and cam are a little lazy down low. Makes the truck a little more drivable, especially when your trying to pass a Dodge Viper on the freeway.
E-Rue
i think what im seeing, is...........
knock at TC lockup. i looked at the file again.
im still runin my PT52 right now. i have a PT74 sittin on my fireplace, just havnt installed it yet. the motor is breathing so heavy now that it jumps into positive boost without much throttle....... kinda like a truck with a stock turbo does. anyway i think im getting bigger boost where you are prolly seeing very litle.
ex. 2200rpm 10psi. at TC lockup. part throttle.
i prolly need to go ahead and install the bigger turbo and see how it does
e
Buster
E-RUE said:
hard to say..... wont be going WOT till i have no KNOCK.
e
Throw some race gas in there until you get things close, that way you can get the major stufff out of the way without blowing it up.
