if im trying to smooth out the transition in fueling from vacume to boost. its unclear to me where i should be making changes.
if i make changes baseed on boost alone, i would modify the lowest entry in the F77 table. the problem is that if i modify the first entry, which is where i need some adjustment, i will in turn affect the entire fuel curve while doing anything in vacuum.
if i make a change to the upper term of the F29 table the fueling under boost will be indirectly affected.
when i look at my fueling curve, i see the ratio go nice and lean as the MAP term begins to increase, (helps with spoolup) and as soon as it approaches 0 vacume and low boost, it goes stoopid rich. there is a difference of 15.5 to 10.9 in just a few frames. its unclear to me what tables i should be modifying to achieve a smoother fueling curve, as all the options seem like they affect too many other parts of the curve.
also, approximately how many frames behind is the WB reading? or is it dead on the money?
e
e
