Chips - Turbos & Bits
James Thomas
"NO CLASS"
Hi all. I have just purchased a 92' Ty and I am new to the Sy-Ty scene and could use a little help with three questions.
1. A friend had a Syclone a few years ago and got an A.T.R. chip # S137TX-528 REV. 1101for it. He said it was great but needed super with octane booster most all the time. A.T.R. is out of business and I can't find any info on this chip he want's to sell me. Any one able to help me out here with specs or real user experience?
2. I will be doing bolt on / non value damaging mods and would like to see about 400-450 h.p. Is this possiable with the stock exhaust manifolds or will I have to have custom headers made? A.T.R. made these but is gone now and I am not finding any other sources if the stock exhaust won't handle 400-450.
3. There are a lot of different turbo setups out there right now and being a supercharger guy (roots type) till now, I am kind of handicapped about turbo specific info. and was wondering if someone can give actual experience based knowledge on let's say several of the turbos listed below:
"We have a very unique very powerful turbocharger that has a fresh professional rebuild and warranty. This turbo is an upgrade unit for the GMC and Chevy Cyclone and Typhoon turbocharged vehicles. It has a new 8 cm turbine housing, a TDO6 turbine wheel, a fresh rebuilt center section with a HI-FI 60-1 Garrett TO4 Turbonetics compressor side. The compressor wheel was purchased new for this turbo as well. This turbo has a T3 style turbine inlet flange and is very suitable for many applications where 500 horsepower is desired"
Note: This company says this is a direct bolt on with no mods required, works with the factory boost control, makes an efficent 20-22 lbs. boost and turbo lag is only 200 R.P.M. greater than stock. A 2800 stall and it would not even be noticed - End quote.
"This a true bolt on full Garrett turbocharger specifically designed for the Sy/Ty, this is not a hybrid. Why spend the money on a ported and clipped 20g (44 lbs/min)? When you can bolt on a Full Garrett T3 / T4 turbo to your Syclone/Typhoon truck. Run a full Garrett turbo on your GMC without changing your manifold and downpipe. This Garrett T04B V-Trim (48 lbs/min) turbocharger will bolt on to your stock manifold and downpipe without any additional modifications. This turbocharger is designed to operate most efficiently at 300-450 horsepower at the wheels (proper engine modifications required). Oil feed and drain modifications required. Also included is our monster 38mm internal wastegate and custom actuator." End quote.
Thanks in advance for helping a "Newbie"
James Thomas
chelo
filthy sy
Re: Chips - Turbos & Bits
Why not just buy that same setup from raceprovenmotors.com Mike also provides the extra stuff that the guy on ebay is not selling. For the same price i believe.
James Thomas
"NO CLASS"
Thanks for the R.P.M. Recommendation Chelo, what are the "extra parts" your talking about?
I might do business with them but first I need to find out if the items I listed are good combos for what I am going to do with this Typhoon. There are so many combos flying around as far as turbos go and those I spoke of are ony two. There are a lot of references to P.T.E. turbos and many others. I am more interested in getting the right parts first and price or supplier second. If it don't work then price means nothing. Any suggestions on good proven combos and parts for a street driven set up for 400-450 h.p.? I don't mind paying the piper to play the game I just don't like paying multipal times. I would much rather pay a little more the first time than double or triple for multipal builds.
Thanks!
James
you can also call e at turbo time. i have bought from rpm and turbotime. both mike and e know their shit.don't buy stuff off ebay and make mistakes like i did. these guys can set you up right the first time and make sure you are taken care of as you decide to upgrade later.
jwaller @ waller performance can also help with a custom turbo that will bolt right in. he built one for tytilidie and he has nothing but good words about it.i have done a bunch of business with him as he lives 35 min from me.super nice guy.
there are several people on this forum that can take of your needs.and will make sure you are always taken care of.trust me you will not get the same treatment from ebay sellers.
Turbo6
10.20@131.8
:tup:
