chips
gjp
another post whore
Re: chips
yes. They are verry common for our trucks. ATR is one company that sold them. What # is on the chip?
the 137a is a basic street chip. it raises the rev limmiter to 6k rpm. no governor, turn on ic pump at lower temp, and few other things.
Flyin Ryan
hated cuz he drives fords
Re: chips
Yes if you use the search feature here you'll see countless threads involving this chip.. as far as I know there were two versions one was a 93 octane street version and the other was a race version which required larger injectors and 100 plus octane I think.
The street chip which is the more commonly found one is simply a two bar map chip like stock with a few limitations and such removed from the stock chip.
Also the Pitbull uses open loop boost control. So it just tells your wastegate to go to x % of DC. You then adjust the wastegate arm to get that x % to match up with your desired boost level. It know I read somewhere that it was made with 16psi in mind even though it's a two bar chip.. so it's just coded to run a little richer.
Other than that, it has some minor tweaks, like limits removed and turn-on temps lowered and stuff. It's generally concidered one of the better and safer of the stockish 2bar chips. Of course im referring to the 137 version which I've used in my truck for at least two years and have had no problems except a rich condition here and there which was resolved.
This site also has some info on Pitbulls I believe
http://www.syty.org/old/promguide.htmls
gjp
another post whore
Re: chips
the 138 is the strip chip and required higher octane. ATR made different chips. some for 40lb injectors.
gjp
another post whore
Re: chips
pitbull is a 2 bar. 137a is used for stock injectors too. 137e is for 40lbs.
Flyin Ryan
Re: chips
all pitbulls were 2bar and I believe the only required modification with the street chip (sy137a) was a 180 thermostate
