Re: CL & OL or just open loop
cvcsmkr said:
I started working on using the stock boost solenoid with my pte44.
i noticed the boost tgt window was blank and after research found out that i need to be in closed loop correct?
heres my question,
i am tuning the ve tables right now, and looking at the wot stuff.
lets say after ive got a good baseline should i switch chip back to closed loop enable?
or is the ecu going to change the VE tables?
thanks
Need to separate some terms... there's 2 kinds of "closed/open loop" that get confused.
The boost control algorithm is independent of fueling closed loop- the o2 sensor, integrator, BLM, and the like.
Closed-loop boost, is another matter.
While you can use closed-loop boost to control boost on a PTE/Garrett turbo, the parameter settings you use are quite different than what the stocker likes. You need to slow things waaay down for the PTE servo canister.
Try this: (Using Paul's NWSTP Tunerpro def files here)
Turn the 'wastegate scaling hack' on... set it to 50.
Set your F70 Desired boost table to whatever your desired boost is. Set all the values in the table to be the same.
Set your POSITIVE STEP ADJUSTMENT TO WASTEGATE and
NEGATIVE STEP ADJUSTMENT TO WASTEGATE to 0%.
Now set your initialization duty cycle table (F71) to a relatively low value, like 40%, all the way across the table. Go for a WOT pass, logging your boost across the run. Get a good long run, through 3rd and 4th gear.
This will likely get you a relatively flat boost, probably pretty low boost at that. You might
have some small spikes at the shift points and TCC lockup.
Up the init value until you get your desired boost across most of the run. This will take a few passes to get right, and keep in mind that a cool motor will respond differently to init dc than a warm one will.
Once you have that, turn the step adjustements back on, but only to like 1-2 ticks, .7 -1%.
Then, you need to check your positive update rate and negative update rate... make sure both are above 1 second.
This will allow the closed loop boost algorithm to correct, only a lot slower than the stock tune did.
At this point, you should be pretty close. You may have some spikes on the shifts, or initially at launch. This is where the scaling hack comes in... the hack changes the F71 table to be MPH based.
Look to see what MPH your spikes occur at, and decrease the init DC in those areas (also, the adjacent ones around it.
Normally, you'll end up with something that looks like this:
MPH 00 10 20 30 40 50 60 70 80
70 70 60 55 55 55 55 40 40
The last thing to test is kick-down boost from a cruise- drive along at 40-50 MPH, and punch it. Boost should stay within 1-1.5 psi of your desired. If it doesn't, you need to change the init table at 40, 50 MPH.
Takes a bit of time to get 'er all dialed in, but it works pretty well once you do.
The new 59 code adds the ability to have different desired boost values for different MPH and RPM, which means you can do different boost in each gear. Future versions will also include an init correction vs. MAT temp, so cold-weather spikes can be corrected as well.
Later,
