Cladding mounting tab reproductions
PPI Typhoon
DIY Madman
So I've been working on some projects here and there.
Sorry for the crappy cellphone pics, but my batteries are dead on my digicam.
Basically......there are 3 shown here, 2 are polyurethane fiber/graphite reinforced reproductions, 1 is the original. I had really bad air bubbles in the first one .....the second came out nice due to a change in the mold and the curing process. I haven't cleaned them up yet. Just pulled them from the molds this morning before I came into work. I'm hoping to have the other mounts molded and reproduced within the next week or two. Then moving on to bigger things
PPI Typhoon
DIY Madman
Re: Cladding mounting tab reproductions
smaug said:
nice, they look good..
good job.
Thanks. They're small beans I know.....but you'd be amazed at how much that mold is costing me. :eek:
It's fun though. I have quite a few bum molds, but it's slowly teaching me what has to be done to make them come out perfect. :tup:
mattw
Thats awesome.. Any pics of the molds and the process that you used to make them?
-Matt
BigBadSmoosh
good stuff, as long as your having fun.. if i think of any projects for you to do, ill let ya know :D
PPI Typhoon
DIY Madman
-Matt
Nope. No pictures. I'm actually not explaining the process because I haven't perfected it yet and don't want to sound stupid. But it's essentially just like any plastic molding.
If you're curious, I know you asked about the fiberglass molding, and it's nothing like that. I'm sure you could make one out of fiberglass, but it wouldn't be very easy IMO.
mattw
I wasn't thinking of making them out of fiberglass just curious of the process that it took to copy and duplicate these..
-Matt
PPI Typhoon
DIY Madman
Well the process, simply, is create a mold, and cast a part from it.
I hate to be that general, but I've been trying varioius different techniques and trying to find what works the best: injection molding, low pressure molding, high pressure molding, vacuum casting, ZIP RTM, pour molding, RTV tooling, epoxy tooling, hard tooling etc.
The trick is figuring out what aid is needed to make the part void-free. My next round is similar to a zero-injection-pressure closed-mold style, but with my own touches to it. The parts pictured above were molded by injection and put under pressure of 50psi. My configuration of sprues and gates, however, caused a void to happen on the very rim. While it's small...and the part could very easily be used, I don't find it acceptable. So in the trash goes that mold, and I make yet another. :)
Joey Allen
MUNCHKIN
Nice job. It's funny you post your repros. As I was looking at my Ty with no f/x I said to myself it sure would be nice to come up with copies of those. I was thinking of maybe billet aluminum having some connections to CNC guys, but hadn't contacted them yet. But, I like yours.
PPI Typhoon
DIY Madman
Well, cladding and the mounting hardware are near to impossible to find when you want it. I don't know about others, but I hate waiting on ebay and hate having to buy used parts that are brittle after 12+ years. So I figure, just make them new.
I agree about the CNC tabs.....but I think it's a bit of overkill. I am waiting on some materials and I'm going to be casting an aluminum epoxy and aluminum urethane tabs to test the strength there. I cast a pure epoxy tab last night. Had WAY too many air bubbles because I didn't degas the epoxy first, but was very very rigid despite the voids. I'm going to keep messing around with different materials and once I have something I like, I'm going to make a mass mold.......being able to cast around a dozen or two at a time. :)
If you'd like......I can send you some to test out when I find that right material. I'd like to see how they are in use. I'm going to hang my cladding with them as well to see how they hold up. :cool: Let me know.
PPI Typhoon
DIY Madman
Ok, new mold........no voids.....came out very nicely. Here's an untreated polyurethane cast, no trimming done.
SpoolingTurbo6
Another Apple user COOL BEANS !!!:rotf: :rotf: Nice Apple cinema display
SEL777
One of 101
Nice job. On to bigger and better things...like a complete set of cladding??
PPI Typhoon
DIY Madman
That's the idea. :tup:
I was originally working on composite reproductions, but figured that's already been done. So I'm making the investment into the casting of plastics....
Granted, the original cladding is a thermoplastic, and I don't have the money for a injection mold (about $36-$60k for just the wheelarch mold). You can do a different type of tooling that will yield a decent amount of parts, but nothing like an injection mold. You can do soft tooling, epoxy tooling, hard tooling, etc.
What I'm working up to is a mold that will mimic injection molds, but not carved out with CNC, but rather an aluminum filled epoxy material. I have to make other reproductions first out of a high-melt material because the epoxy exhibits a LOT of exothermic activity when curing, especially in the area of molding because the thicker it is........the more heat is generated. This heat can be enough to melt a piece of cladding. So....you create a higher melt replica of the cladding and then make the epoxy tool out of that. Should be good for making several dozen castings depending on my preparation. I've also been talking with my girlfriend, who is educating me on the chemistry behind the plastics I'm using and all the additives I've been experimenting with (some that I could blow my apartment up with :rotf: ) so I'm trying to learn as much as possible. The real trick is in the design of the mold and the materials used and preparing the materials. If the mold isn't made right........you'll have air pockets. That's a LOT of material wasted in a bad mold. Plus, how you prepare the materials has a lot to do with it. For instance, you have to degas your materials, so you need a vacuum pump (which I happen to have a very nice one already) and a vacuum chamber to do this process. There is also different ways of getting the material in the mold. This is what I'm working on now. Anyhow, I'm rambling, but you get the idea of what's going on.
So essentially, each mold will be made a few times to get this process down. The materials range from $75 to $150 a gallon. Just the wheel arch takes about 5-6 gallons of material to make the mold. Then I just spent $60 on only 10 lbs of filler materials, which is the explosive part of the equation. (Still a little timid to start working with these).
So yeah.......that's it in a nutshell. ;)
PPI Typhoon
DIY Madman
Well, the last mold came out great. Looks like I have a winner.
This is a pic of a piece that I took out prematurely because I was too excited to see. You can see where I got some specks of dirt and tried to scrape it off (towards the center) and you can see where I've been man-handling the edges where they're all rough now. It's supposed to take 6+ hours to demold and I took it out in like 20 min :)
But here's a good shot with the digicam of the detail that it pulls off.
