I have a classic FAST ecu along with the harness for plug and play into syty. It includes NTK wideband sensor.
I have a file once you fire it up to also open up to use off the shelf o2 sensors in the future, direct from FAST.
The bad: Injector harness to injectors is missing. Plug on ECM side is there, just not injector side.
o2 sensor plug is cutoff, probably by last guy to fish it through a hole in firewall. Its all there just needs put back on, probably after you fish it back through.
Harness alone in the day was $400ish I believe.
$575 for everything.
