Cleaning carbon off pistons
Hu Ryde
What can I use to clean excess carbon and oil off my pistons? Remember they are still in the truck. Scotch Brite? Carb cleaner? Steel whool?
Tydriver
TurboLS6 Powa'
Hu Ryde said:
So there is nothing to do to it while the heads are off? 100% Alky?
Nothing safe. I would be concerned about scratching the cylinder bores or contaminating the rings etc.. Leave it alone, install alky injection when its back together and U can steam clean it !!
Haaa haaa..
myclone
Ive done the following at times (I'll get flamed off the planet but Im beginning to actually like it for some strange reason :wink: ).
Get yourself a BRASS wire brush thingy that you can chuck in a drill. The brass wont hurt the cyl wall/piston unless you put a lot of pressure on the drill or hold it in one place while working. I get mine at a local mom n pop hardware store (they got all kinda cool thingys that Lowes dont have).
Pick a cyl to start on and roll the eng over till that cylinders piston is at TDC. Cover the other cylinders/rest of the eng with rags/towels/whatever. Use the brass brush/drill to clean the top of the piston as much as you can. You'll get most of the carbon off but Ive never been able to get them "looking like new".
Keep the brush moving. Dont let it sit in one spot as even the brass will start to eat into the piston eventually.
Once the piston is as clean as possible start rolling the eng over and moving the piston down in the bore. Use a rag to clean the bore as you go. I move the piston down about 1/3 of the way and clean. 1/3 more clean again. Then again at BDC. IMO this "pulls" the piston away from the debri that gets flung onto the cyl wall and down into the space between the cyl wall and piston allowing you to wipe it off. If you do the cleaning and the piston is not at TDC then when you roll the eng over to clean it just "wedges" the debri into the rings/bore/piston poss causing damage.
Repeat for the other pistons/bores.
If you have compressed air that helps clean the loose crud out too. Just be careful where you direct the air so your not blowing the debri into the eng.
Once its all done and the eng is buttoned up I fire it up for a few minutes then change the oil.
HTH.
(BTW.. the alchy method would prolly work better and be ten times more fun to do)
2cold
When the engine is hot and running spray water in the intake, that will take the carbon off the top of the piston.
