Double-A
Quitter
Does anyone have any recommendations on cleaning fuel injectors or of a reputable business to do so? I managed to get my truck running after many years of sitting - I siphoned out what old fuel I could and added fresh, but I'm thinking the injectors may be clogged open. It started up and ran with a slightly high idle, and excessively rich - so rich that it eventually stalled itself out and wouldn't restart. Surprisingly no codes, which is why I'm going out of my mind trying to figure out the issue. All plugs are excessively fouled and black, some worse than others. It's so rich that it's painful to breathe while behind the truck when idling.
I've already replaced the AFPR (diaphragm shot) and the O2, plus found a bad ground to the 3-bar which has been corrected. They are the ones that were in when I had my little underhood BBQ, but the fire didn't seem to get to them. (visually anyway) Also replaced plugs/wires/cap/rotor, among a lot of other random things like the wiring harness and all hoses. TB is a used unit I bought off someone eons ago - included IAC and TPS.
I've watched a few youtube vids about testing/cleaning the injectors at home, just thought I'd ask if anyone had anything to add or had someone that they'd recommend rather than me trying it at home.
The only other things I can think of are (1) that I got a faulty O2 replacement, which I've never heard of but I suppose is possible, or (2) the spark isn't powerful enough, pointing toward a spark issue. Maybe there's more to it that I'm missing, but this seems like the most obvious next step.
Thanks folks
Thanks folks
