Closed loop program for my 75s and vortecs
Trapper
Well I found my problem with my Ty at purchase and tired of getting the run around with my seller, I have a open loop chip but I would like to have the closed loop program for around town. Anyone have any recomendations other than E Rue, Thats who my seller has dealed with and I'm getting not any good support from that end, I was told he was busy, but sent back my PCM and Chip in a plain box with no packaging when I sent it with a good box I get a girly shoe box. So any positive sugestions would be real apreciated, since my seller is really trying to just pass the problem on to me since I was told the truck was running great when I bought it. Thanks Trapper
TYTILIDIE
METH HEAD
Re: Closed loop program for my 75s and vortecs
Its easy to put in to closed loop. Any idea why the chip was left in open? There are several people here who can JUST put it in to closed loop mode. Hell, I can do that :lol:
cloneman315
i can tell you for sure the 75 open loop erue sells is a very good chip, and the driveability on it should be very very close,you might have some other issues,i run the same open loop chip setup and my truck runs like a watch
sy#2921
BAMF
The chip trapper has is a phil long 75# chip. I know personally that Phil reburnt that chip for me to his v.3 then I sold it to sy1219.
sy#2921
BAMF
Well that chip worked just fine on my truck. It didnt like AJ's truck much but he had a huge TB among some other mods. However I can't believe its not close
Trapper
With this chip it seems to run good but it idles fine for a wile then goes lean and dies without any help. But I just used this chip to diagnose, my other chip was I thought the main problem. But I have been told that an open loop is more susceptible to die at idle.
TYTILIDIE
METH HEAD
Sounds like putting it in closed loop is not the answer for you. You need a tune done for YOUR truck.
Trapper
Well I did put in a new IAC just recently because I was checinkg the old one and it snaped off, so I will do that first, But ya I was told by my selller that the chip was specificly for my Ty.
But it is so much easier to just hope an "off the shelf" chip will run perfect.
Who wants to actually do any tuning, that takes some thought beyond a wrench.
Sorry to get on my tuning soap box.
When various mods are done to these trucks, a custom tune will always be needed. This isn't to say you don't have maybe some other problems. But just learning how to read a scan tool can help so much. Once you know what to do with scan tool, tuning itself is not that difficult.
I've seen a lot of people jump over and try code59 who never knew what tuning was before. Sure at first it is a bit overwhelming but things will click if you desire.
It doesn't matter if you have stock chip, code59, FAST, BS3, etc.
Sounds to me like you have maybe some mechanical issues as well as the tune can be improved.
Trapper
I understand that these off the shelf chips are not one size fits all but I bought something from someone and it wasn't in the shape I was told it was in and now I'm jus trying to fix it. I will get my Datamaster on it.
Trapper
Well hooked the datamaster up and its giving me info but I dont know what I'm looking for. But when I pull a vacume tube it idles pretty good, At least its not dumping fuel in the motor like the other chip was doing, my wob2 is telling me its at 19.0 or even as high as 20. when I first put this chip in I forgot to put in the brown part of the chip and it was running a little rich but it ran a little better. If anyone can help it would be much apreciated.
Trapper
Ok I think I have it running better I swaped the long chip on the chip adapter and now it wants to hold an idle better and warms up to 14.5 give or take on the wob2 well see I will take it for a test drive.
