clutch pedal
jjorgensen52
NHSTE - I'm the only one!
Anyone know if I can use a pedal bracket assembly from a G / F body car in my truck? They are a lot more plentiful than s10 assemblies for whatever reason
tippmann243
Re: clutch pedal
no they will notthe assembly and geometry is WAY different
i manged to pull one assembly out of a wrecking yard and man is it a bitch, the only way i could get it put was to pull the dash since there is one dolt thats impossible to remove with the dash in. the things i do to have a t56 :rotf:
edit i can snap a picture of my assembly if you like?
SY2455
70's Veteran
Re: clutch pedal
I may be able to help you out if the truck is still there. It had a Muncie 5 speed in it. What all do you need? Is the clutch and brake pedal enough or do you need the clutch master cyl and hose assembly down to the slave cyl too? I have an old 1982 S-10 in the side yard that has just the pedal assembly for an old school clutch linkage. Let me know.
jjorgensen52
Re: clutch pedal
Just bought the pedals from a boardmember last night... thanks for the offer though.
tippmann243
Re: clutch pedal
wait till you get the assembly you will see what i mean by a bitch to install.
the bracket is ****ing monsterous
jjorgensen52
Re: clutch pedal
yep, I've tried to remove one from a truck at the junkyard.... I figured doing it once would be enough :lol:
