Code 31 33 and 43
syclone 0260n4
I just pulled some codes on the sy and heres what I got
Code 31 wastegate over boost
Code 33 map sensor too high
Code 43 electronic spark control failure
Right now the truck surges back and forth on idle from 600-1100rpm sometimes higher and lower on each end, overboosts and is slow to start. I think the map sensor is goin out causing the idle but not 100% yet. Im not sure if one of the things wrong is setting off the others but....
If it pulls code 33 does that mean the map is for sure bad/faulty?
Also the truck is 100% stock with the exception of 3" cat back exhaust, could the bad map cause it to cut out under higher boost?
syclone 0260n4
Re: Code 31 33 and 43
Ok just replaced the map but it seems to run worse now but maybe just me, its a wells brand from autozone.... I also pulled the codes again after disconnecting the battery replacing the map. I ran the truck for 30 mins before pulling codes and the only one i have this time is code 43. I think the 31 and 33 just havent had time to appear yet
If I still get a map sensor code could that be the wires leading to it or something else causing it to throw off the map?
I just now tested the fuel system and it reads 31psi at idle and 40 at rev
Also, the truck does run awesome otherwise and seems to have full power after
