Code 31
aasltmike
Tried finding some info on code 31, but no luck. The info I find is it says it is a wastegate solenoid circuit error. Does this mean the boost control solenoid is bad?
Osmosis
Re: Code 31
If I remember correct, it is an overboost condition. Are you running the stock chip, stock boost level? Have you got on the throttle hard, had the truck stall during high boost? If so, that's the computer shutting down the truck for a safety meausre. Or a measure that the factory set. Before I went code 59 or ultimate chip, I had that happen a few times. Just disconnect the neg battery connection for a minute to reset your ECM.
powercat6
Re: Code 31
X2 on overboost. I'd recommend checking the vacuum hose on the boost solenoid, may want to replace it just because. Also your wastegate actuator may need to be adjusted. Could also be a faulty wastegate solenoid.
aasltmike
Re: Code 31
10-4 on the truck stalling while getting on it hard. No mods to this truck other than replacing the cat and muffler. Stock pipe size all the way back to the muffler, then it flares up to 3 inches to join onto the muffler and 3 inch pipe all the way from there to the tailpipe. High-flow car and high-flow muffler, so could that be causing the overboost?
aasltmike
Re: Code 31
I'll replace the hoses, but a check on them shows them to still be soft and pliable - no dry rot, hardening, or cracking. Any input on how to adjust the actuator? And is the boost control solenoid and wastegate solenoid one and the same, just different names for it?
powercat6
Re: Code 31
My service manual has the procedure, if no one else chimes in with instructions I'll bring it to work tomorrow scan the pages into a pdf and email them to you. As far as I know the Wastegate solenoid and boost control solenoid are the same thing.
aasltmike
Re: Code 31
Much thanks for that! That'll be another project for me to do! LOL
The_Bronze
Re: Code 31
Code 31 is caused by 30psi of boost detected by the PCM for over 2 seconds.
Per the Manufacturer:
Code 31 is set when the PCM detects (using the MAP sensor) a pressure that exceeds 29.732736 PSI (Thank you IPhone for that conversion app) for two seconds and Code 33 has not been set. The check engine light will stay "on" ony while the overboost exists. The light will stay "on" for 10 seconds after the condition exists and then go "out".
An overboost condition could be caused by:
1) CKT 471 shorted to ground
2) A sticking wastegate actuator or wastegate
3)A control valve stuck in the closed position
4)A cut or pinched hose
5)A faulty ECM
An extremely dirty air filter
Wastegate description per the manufacturer:
The wastegate is normally closed, but opens to bypass exhaust gas to prevent an overboost condition. The wastegate will open when pressure is applied to the actuator, and is controlled by a wastegate control solenoid valve pulsed on and off by the ECM. Under normal driving conditions, the control solenoid is energized all the time which closes off the manifold pressure to the wastegate actuator. This allows for a rapid increase in boost pressure. A boost increase will be detected by the MAP sensor, and the ECM will pulse the wastegate control valve. Manifold pressure will then be allowed to pass to the wastegate actuator, and the actuator will open the wastegate. This will prevent an overboost condition on heavy acceleration. As boost pressure decreases, the ECM closes the control valve and the wastegate actuator pressure bleeds off through the vent in the control valve. If an overboost does exist as indicated by the MAP sensor, the ECM will reduce fuel delivery to prevent damage to the engine.
If the level of coolant in the charge air cooler (CAC) is low, the turbo boost cut-out relay will shut off all power to the wastegate solenoid, causing the wategate to close. The "low turbo coolant" lamp will remain on until coolant is added.
Interestingly enough, when the ignition is on and the ALDL terminal is grounded boost solenoid should be energized. I didn't know that, it makes for a quick test.
BMFB
Not to scale
Re: Code 31
It’s an over boost, the stalling your getting is your truck shutting itself off to protect itself. It’s likely from removing your stock exhaust system, now that your exhaust is freer flowing, your turbo is working more efficiently, and your boost control solenoid can’t control the boost anymore. The best thing to do is not get on it, because you will be getting allot of detonation, and it’s really bad for it, to fix it, you can get a higher flowing cat, or something of that nature to put some more restriction in your exhaust, so it’s back under control. You can also get chips, or run Code59 to counteract the problem. Some people say you can tighten up the spring on the waist gate, and that helps, but just be easy on it, you don’t want to ruin your motor
