Code 32 problems
aasltmike
I am having some issues with my Ty setting a Code 32. I recently went back to regular rubber vacuum lines when I discovered that the silicone lines that I had put on there were getting too soft from engine heat and were coming off the fittings. I also replaced the EGR solenoid. The light seems to come on when I am at cruise speed on the highway and the truck has been running for awhile. The truck will slightly decelerate as if I were putting on the brakes, then the light comes on and the truck starts to suck gas like it's going out of style. I checked the EGR valve by putting vacuum on the line and the diaphragm pulls like it is supposed to. I did notice that when revving the engine, the diaphragm did not pull back and forth. Could the EGR valve still be a possible culprit?
1madgumby
Re: Code 32 problems
Unplug it, & put A block off plate in its place. through it in the garbage. just my .o2
gkrcr882
SyTyless......for now!
I've heard that an old speedometer cable or something similar works well to clean out EGR passages. Just a heads up, use caution when working around EGR parts, burns are very likely! Reason fuel economy bombs is because there is no inert gas to displace the fuel/O2 mixture in the combustion chamber. NOx emissions will be higher too.
aasltmike
With the engine idling, reach behind the EGR valve, and pull the diaghram in with your fingers. The engine should stall right away. If it does not, the passages in the manifold are plugged. Pull the upper intake, and figure out how to clear them.
Above test OK: Check the EGR diaghram by sucking on a piece of hose connected to it, with the engine idling. You should be able to stall the engine.
Still OK: Double check the connections both electrical, and vacuum, at the solenoid. Also be sure there is 12V present at pnk.wht wire with key on.
Removing the valve, and installing a block off plate will have the same result as you have now: Inoperative EGR. Sets a Code 32, and the light will come on. Under cruise conditions is where the 'test' runs and fails.
Check the passages.
OK, I performed the first test and the engine bogs down, lopes at low RPMs, but will not stall out.
aasltmike
There's your problem. The passages are plugged, but not completely. That's what you feel under cruise: The system is testing itself.
Remove the EGR Valve. There are two passages. One into the intake. Tape it off with some duct tape. Start the engine: You won't feel much exhaust at all out of the other one. Start digging the passage until you get some good exhaust gas flow. You may have to pull the upper intake, but I'd try at the valve first.
That should do it.
Thanx! I'll try that and let ya know how it works.
I don't remember the symptons exactly but a local kept have problems with his EGR, his hard lines kept slipping out of the EGR soleniod on the driverside.
aasltmike
Well, I finally figured out what my issue was with my Ty kicking a Code 32. Was under the hood checking out the exhaust port to the EGR valve and there was a little mess in there, but not enough to make me believe this was the issue. I cleaned it up anyway, though. I was looking at the vacuum line diagram again and noticed that a check valve coming from the EGR solenoid was installed BACKWARDS!!! :rant:
Anyway, I changed it around and, WHAM-O! No more check engine light! LOL
1madgumby
Michigan might be cold as hell in the winter but we have no BS. emissions testing garbage. :)
