code 33
BoostedSUV
Re: code 33
whys that
because you already pretty much know you need to rebuild the motor. You're getting blow by, the truck wont idle right, and you started a thread about needed a rebuild. Why worry about a CE code when the motor has to come out? :dunno:
syty9933
Re: code 33
im not sure it needs a rebuild yet, ill do the compression test soon, and i dont know if its blow by and i fixed the idle
BoostedSUV
Re: code 33
I missed the post about fixing the idle. What was the solution?
Check the vac line to the map and that the connector is securely connected. Also check that a wire didn't break off. I had a wire break off inside the insulation. I gave it a little tug and it snapped off.
syty9933
Re: code 33
in my datamaster it shows i was running lean at idle. Is that because of the map, or is it causing it and i just need to adjust my fueling?
