Code 43
Turboz
NASTE
I have been getting this code for the last couple of days. It says ESC Failure. I checked on sportmachines and found this Code 43 Electronic Spark Control
(ESC) The ESC retard signal has been on for too long or the system has failed a functional check. My question is what could cause this and why. I have searched I didn't come across anyone having this problem. I got this a while back and figured I needed a tune up. Also changed the ignition module while I was there. Didn't see the check engine light for a while except for the IAC code. But in the last two days it is on quite frequently. Dosen't matter driving conditions either fast, slow, idleing, etc.
Jay
Turboz
NASTE
Re: Code 43
Ok chenged the knock sensor today all I can say what a pain in the ass. Now that it is changed no more check engine light but I don't think it is working I got into it once and thought I heard pinging so I let off and didn't try again. I have a DM file if some one wants to look. Or anything else I should look at.
Jay
Re: Code 43
Jay,
Did you torque down the Knock Sensor with a torque wrench, its supose to be 18 ft-lbs.
Turboz
NASTE
Re: Code 43
yeah I torqued it down. I will recheck it though I went 19 nm which i believe is 14 or 15 ft lbs. I found that in a search so if your saying 18 ft lbs then I will redo it. I ran DM on my way home and I did see some knock retard so maybe it is working and I just have little knock. If anyone wants to see it let me know and I'll email it.
Jay
