Code 43.
jusssi
My truck is giving cel and code 43 just after couple of seconds after start. I have tried with new knock sensor ac-delco # 10456288 new ign module, checked line between sensor and ecm... what else? Which is right knock sensor for these trucks? What can be wrong with my truck? Also I tried wit another ecm and with stock and atr memcal. :(
Logan
Re: Code 43.
Did you over torque the knock sensor? Do a little searching on here and you will find a thread with the part number and torque spec. I believe it was 14lbs? IIRC.
ajt86
Re: Code 43.
yeah knock sensor torque is pretty essential for it to work right
if you have a scan tool monitor the knock sensor with the key on engine off it should be 0 then tap around it with a screw driver- see if its even reading a signal
jusssi
Re: Code 43.
Ok, thanks for responses. I found out that right part number is 10456549. 14 in lbs is so low value thet is pretty easy to over tight it.
jusssi
Re: Code 43.
I got new knock sensor today and before Iput it on need little more information for torque.
Is it really 14 in lbs or is it 14 ft lbs?
