Code 44 issue
prosty
The tranny breaker
Just had my truck running again after tranny being rebuilt and ATR headers put on. Got both Code 43 and Code 44 a while back. 43 was caused by knock or map sensor (is it called sensor in english? :roll: )
Anyway.. drove the druck home. Ran pretty ok. And after a while Check engine appeared (have no tec-1 or DM) so I "hotwired" and read code 44 Lean Exhaust. Does anyone here have any info about it? Or similar situations? I've read on syty.org and I've already got a stock oxygen sensor (AC Delco) Could this be a vaccumleak?
Got a walbro 255 fuelpump. afpr and 42 psi base fuel pressure.
What could be causing this? Or do I have to refer to the syty.org troubleshooting guide?
br Markus
jwaller
Evil Genius/SyTy Guru
could be a bad o2 sensor. what chip do you have?
I dont think a vacume leak would cause a low 02. it's got plenty of room to compensate for a vac leak.
prosty
The tranny breaker
The ECM was just reset before I drove the truck home. But I'll do that and see if it happens again.
