bender
I knew it was coming after the drivers side gaskets failed. The passenger side went this weekend. So I removed upper ic. And loosened manifolds. First tried no gasket but it leaked bad. So I put new gaskets in and all seems well. I am getting a lot of condensationfrom the exhaust pipe and some is leaking at the dopwnpipe turbo flange. I torqued the bolts but it still drips a little until it gets hot and it evaporates right away. I went to drive today and datamaster is showing code 45 rich and. I didn't try to drive so I don't know if it was leaning out. I didn't change anything but the gaskets so I'm not sure what happened. When it first started it stayed in open loop even once temps were up to 160, I have 180 tstat . I shut it down and restarted and it went closed loop but code 45 stayed. Amy ideas
Sorry about the grammer I'm on my phone
