code 45... but why? (kinda long)
Flyin Ryan
hated cuz he drives fords
Firsts off, search feature sucks the big one, anyway
I'm getting a code 45 o2 rich so I need some help. I replaced the o2 sensor two days ago and everything else listed below at the same time.
ATR wires, fuel filter, oil filter, trans filter, cone kn filter, 3bar map, jabsco ic pump, pcvs, serpentine belt, 02 sensor, swap stock chip with custom burned chip, and cr42ts plugs along with all fluids in truck changed. Replaced most of the vacuum lines with silicones. Also replaced all fluid in the entire truck.
The scary part about this is that on datamaster my knock count cycles constantly like 02mvs would and they don't stop, even at idle but no spark retard...until the 2nd to 3rd shift and it gives 18kr, I see the S term counts drop from a steady 128 at idle to 80 then the code pops up and hello open loop. If you get into any boost at all, spark retard jump striaght to 18+ :eek: which before everything listed above I had 3 kr at the most during wot. Oh and I originally replaced the p2 sensor to clear up a o2 lean code I was getting :evil: oh and in the bit data table it shows that the truck is extra extra lean... I checked the fuel pressure it's at 50 with vac line on and without the vac line connected and pluged it reads 60.
I will have a dm file posted later tonite on this but need some help, Im not too mechanicly inclined so go easy on me. :D
anyhelp or suggests???
Flyin Ryan
Re: code 45... but why? (kinda long)
what was the fix I'm having similar issues
it's been a long time but I remember the whole issue being the custom chip someone burned for me... they apparently had no clue wtf they were doing. Couple that with a new o2 and the problem was gone.
