code59 idle question
SyTyAddict
I got the Sy running on code59 this morning, I had to add an extra 60* of timing into the tables for it to work with the DIS, but it worked out better than I had planned. I have been messing around with the base pulse constant to get the proper a/f at idle. It idles around 14.2-14.5:1 and is smooth as glass, it will idle like this for a minute or two and then suddenly rpm starts to fluctuate and the a/f goes lean. Sometimes it will smooth back out after revving the engine and it will repeat the cycle again after a varying amount of time. As long as the rpm doesn't start to fluctuate the a/f is pretty decent. I'm new to tuning and was curious if there is something that I'm missing.
Re: code59 idle question
There is a way to offset the timing in another table. Will have to look when I get home, dig would know more.
Idle that wanders is typically due to fuel going lean or rich, idle moves to lean spot rpm goes high, goes back to rich or normal area, settles down, goes lean, rpm goes up..etc etc.
In the idle area as a test put all the VE's# very similar, especially the 400 rpm area. See what happens. I typically will make the VE in 400 cells a few # larger to catch any drops in RPM.
WyoSyclone
also check to see what your timing is at idle. I've found that adding some advance at idle (via the F1 table) will load the engine a bit and create a smoother idle.
Sportmachines
I agree with with Jeff and Wyo. I would also add, if you smooth a section of the VE table, Smooth that section of the timing table as well (4-6) cells, this will make it smooth and eliminate any hunting IMHO.
SyTyAddict
The timing is right around 20* at idle. I'll have to try smoothing the same cells in both tables, I smoothed the cells that are being used in the F29x but not the timing table. It idles dead smooth in the 13-13.5:1 a/f range, it starts to hunt rpm anything higher than that.
WyoSyclone
Try the timing up around 30 to 32 degrees at an idle and see if that straightens it out. You may have to lean it out a bit when you do that.
Sportmachines
Wyo is right, that works. In my personal experience, I keep the top left corner of cells in the timing table in the 20 range, and keep the afrs a bit rich around 13.5 -14.1, and they idle super smooth.
The Bronze
I was of the understanding that base idle timing is kept low (around MBT) by design as small idle speed adjustments are carried out by ignition timing (as it reacts quickly), while the larger adjustments are carried out by the idle motor (which is slower to react). Doesn't increasing timing, say beyond MBT, remove the PCM's ability to control idle, as the timing fails to increase or decrease engine torque and thus forces the idle motor to control the idle?
For now all I can do is ask the stupid questions, as I am still a few months away from tuning code 59. :oops:
SyTyAddict
Just a little update; I got it to idle well a few days back using the methods that were suggested. I have been using autotune for the last couple of days and it is slowly coming together.
Thanks everyone for your help.
