Code59 + Wideband?
Sean Krupa
Moderator
How many guys have had a sucessful tune with Code59 without a Wideband o2 sensor? Being that I had Hood burn me a 3bar chip and it was running pretty good, I just want to step up to Code59 for a better tune. I feel more $$ is going out than is coming in right now.
My Code59 equipment is coming in soon.
Thanks,
SyTyAddict
Re: Code59 + Wideband?
I have been getting my Sy running on $59, I have to say that I think it would be very difficult. I would especially be uneasy when it comes to boost tuning without it. I'm new to the tuning thing though, I'm curious to see what the more experienced members will say.
DubJG
Im not one of the more experienced members by far but i feel like a wideband is worth the money and then some when it comes to tuning. Especially because the support for it with other members is worth its weight in gold. But i would be interested to see how well narrowband tuning could be done
ziembic
I would think that trying to learn tuning with the narrow band would be pretty frustrating. When you make changes, unless in very small increments it will be harder to see the difference. The narrow band has a range from 0 to 1000 millivolts. The wide band has a range from 0 to 5000 millivolts. Changes will be easier to see since the range is farther. It can totally be done, but you will be much better off picking up a wide band and routing it into the computer.
It's just a six
Super Member
It seems so many guys w/there Buick GN & T-Types tune a lot w/just there narrow band O2 sensor. Even to this day.
I do not see that as a good choice but for the Buick guys it seems to work reading there millivolts.
Sean Krupa
Moderator
In your opinion, why do you think most Buick guys don't convert to Wideband? Isn't it more easier to tune, or is it just the accuracy that makes WB worth it?
Either way, I'm going to get Wideband sooner than later, just looking for opinions. I have a pretty good tune already. Again, just want the tune to be almost perfect and see how far I can go with just Narrowband for now.
Thanks,
It's just a six
Super Member
Years ago guys (Sy/Ty guys) used to run Diacom & read there millivolts also on there narrow band for tuning.
It will get you in the ballpark for tuning, but it is very slow to react.
Wide band is much safer, it's affordable, before they used to cost $1000 plus dollars, that's why guys did not get them.
No reason not buy one & be safer using a wide band.
