coil and map mount alternatives
NecroWolf
lost marbles member
so what is everyone doin for alterbate mounting locations for the ignition coil and map sensor? this has really has to go. i hate having it there and adjusting valve lash is quite a pain having to pull all that crap out of the way to pull the valve cover. any ideas would probably be better than mine. i was thinking self taping screws for the coil onto the hvac box and maybe the same for the map. pictures would be even better.
Norm
Re: coil and map mount alternatives
you can bend the map bracket or make a aluminum one and mount it on the firewall.
NecroWolf
lost marbles member
anywhere in particular look nice or presentable atleast?
Norm
Mine was mounted on the firewall by the distributor/heater core. There's not alot of room there. But a coil could go pretty much anywhere, you would just need a longer wiring harness, and for the coil/distributor wire just use a longer spark plug wire.
