Cold running motor
MR_MNZTR_SY
whoa, i had no idea you got scope readings off of datamaster. dammit im so far behind. anyway, what temp do you need to be at to go into closed loop?
MR_MNZTR_SY
that dm post of yours says that you are 23 degrees advanced at idle. i had a bad MAP sensor that was causing that. that may be part of the problem too.
Hu Ryde
The 23*'s is normal as far as I know. If I disconnect the tan wire it will be 0. Open loop goes closed not by temp but another aspect I believe, not sure though.
Falco
I guess this low knock count is because
A) Jesse removed power to the ECM recently
and/or
B) It's an older DM version which increases your knock count by one at every knock event oposed to the latest version which steps several hundreds at once
Not a big deal anyway. :roll: However if it's not the latest and greatest DM, you should upgrade it, because
A) It's free :lol:
B) Has better understanding of the 3bar boost values, hence more accureate boost readings
Peace,
just a 6
R.I.P MyClone
How do i know i have the latest version of DM? Here is my DM info:
Version 3.4.1
Build date December 01 2001
Cal Table Date June 23 2001
A) It's free :lol:
