Re: Cold start belt squeak
Update...
I got a new drive belt again, going to try a gatorback belt this time.
While the belt was off, checked all my pulleys for movement or noise. ok
Cleaned out the grooves on the powersteering pulley with a metal pick to get out the
debris. then sprayed brake cleaner on all the pulleys. Then blew with shop air.
I found my alternator has been changed before and the pulley looks like it had been dropped before. Has a dent on the face of it causing the belt to ride in and out.
going to try and get a replacement. Need to drive it to work until i get one.
Installed the new belt and all noise gone for now. Hopefully it stays gone this time!
Note, I sprayed with water, noise went right away then came back even louder. So I knew i
had some miss alignment somewhere, but it never quit making noise to work and back.
It was very embarrasing :rant:
