Cold start help
Neelsonwheels
So my Typhoon runs pretty well thanks to Tom and Alex tuning
It. I am having some trouble with cold starts. It is really hard to start after
It sits and cools. I have to open the throttle to get it to fire then I need to
Keep working the throttle to keep it running until it's good and warm.
Then it will idle fine. To start I am running Bigstuff and all the usual
Stuff has been done. Plugs,cap,rotor,iac,vac lines are new,throttlebody is new,
Ignition is new(MSD 6al), TPS new, map sensor new, fuel filter new.
I am pretty sure it is in the tune. Cold start wasn't addressed due to time.
I was wondering about the after start settings but don't have the confidence
To mess around to much. Bigstuff guys help me please. It is embarrassing
Leaving case shows and fighting to get her running.
jaystcb
Sy 0902, 92Ty 0909
Re: Cold start help
Is this something that just started happening? Does it do it all the time on cold start?
Neelsonwheels
Re: Cold start help
All the time on cold start. It has been like this ever since the turbo/upper intake/throttlebody
upgrade this winter.
Slyclone
Well-known member
Re: Cold start help
Jeff, I recall having a cold start issue back when my truck was fussing up. Some one at the time reccomend a upper intake coolant sensor. It has 2 wires and I think it plays a role with the cold start hard start issues.
I am not sure the parameters of big stuff and if the sensor is even used or recognized. I do not know anything about a stand alone.
Neelsonwheels
Re: Cold start help
I will try anything at this point!! thanks for the input. You must be referring to the lower intake. that is where the coolant temp sensor is. The intake air temp sensor is in the upper
intake on the right in front of the brake booster line.
randy merritt
Re: Cold start help
sounds like your startup enrichment may be fat. also look at your after startup enrichment tables. I have no clue about Bigstuff, but I had the same issues with my Holley. If you have to open the throttle for it to fire cold, then the startup enrichment is to fat.
Slyclone
Well-known member
Re: Cold start help
There is 2 coolant sensor. One on cylinder head driver side one wire green
I think the other is on the lower intake manifold. I didn't mean to confuse you about a intake air temp. Sensor.
Like I said I don't know what big stuff does. A lot of the times it seems like tuners can tweak anything once you have one of them operating systems.
I just remember the 2 prong coolant sensor. I have a brand new one here if you don't have a readily avai. One. It is a delco part.
Neelsonwheels
Re: Cold start help
nope one coolant temp sensor. it is center of lower intake by the thermostat housing. the sensor on the drivers head is only the engine temp and all it does is the temp gauge in the dash. no worries I am not confused. LOL
Neelsonwheels
Re: Cold start help
That is the way I am .leaning. I was told by a very smart guy the same thing you say.
I don't want to keep bothering him. The after start I will look into it. I am wondering about the IAC also.
randy merritt
Re: Cold start help
You would be really hard pressed to hurt the motor by messing with the startup enrichment. I understand your concern about hurting the motor, but I think the worst you could do is foul the plugs. I think the hardest thing about tunes and self-leaning computers is getting the startup right. The setup I am using will not go into closed loop (compensating for the AFR off the O2), until the motor is up to operating temp. Getting it up to that temp can be a job in the beginning. I am still struggling to get my startup fueling perfect, but I have got it close enough for me for now.
Pull some fuel out at startup and give it a whirl.
