Cometic cylinderhead gasket
cat-vi
Ty Wannabe
I'm about to install vortec head and will be using the cometic cylinderhead gasket, the holes for the cooling water passage in the cyl.head gaskets seems to be very small, is this sufficiant? what tourqe is prefareable to use at the ARP cyl. head bolts? thanks.
Quickstop [UK]
Combating adversyty.
Re: Cometic cylinderhead gasket
I use a Cometic and have no problems. I also used the factory torque guide with ARP bolts and the factory pattern. 25#,45#, 65#
Good luck!
cat-vi
Ty Wannabe
Good luck!
Ok, thanks, I guess you noticed I wrote cylinder head and not cylinder heads, still waiting for it:rant:
Quickstop [UK]
Sorry man - that is a looooong time. How much did you pay? Ask for a refund, buy two old ones, recondition them and use one as practice to get the other or get a spare?
That is too long. :rant: indeed!
Big Mike
I will suggest you call Arp and get the correct torque specs for the bolts being used. There is different torque specs if you use oil vs arp assembly lube vs other stuff. You really need to find out from the source...Arp.
Quickstop [UK]
I used ARP and they had the same torque settings in the manual I had IIRC. It does also depend on the lube used - again, I used the ARP lube. It can't hurt to check though. :2cents:
cat-vi
Ty Wannabe
well noted, thanks.
