Comp Cam 422 help...
I've been seqrching but couldn't find anything related to the 422. I need to know what all i have to have to get it installed. Like chip or computer moding. Any help would be appreciated.
Re: Comp Cam 422 help...
man, that was a fast reply. im thinking of getting the 96 vortecs and getting them machined in. what chip and where can i get it?
DanenGraham
Big in the rear
To get full power gains from the 422. You would have some head work done, or go L35's or Vortecs. The stockers just dont flow that much air. So you need Heads, Cam, RR 1.5-1.6, Valve springs, locks and guides, (Lower intake mod, as well as new heads drilled) vortecs
You may see some gains top end but, i dont think it will be much. That cam will start to get into its power range when your shifting.
EDIT: on the chip, you would want to go 3bar map, and custom burn. If your doing all of this i would say get #50's while your at it. If your getting heads, cam, chip, you might as well up gade the fuel system. You are going to need them. (get the walbro 255HP for a fuel pump)
Syonara
HaHa thats what i had to do! There is no simple mod or one that will make our trucks fly--its all about the combo!
You won't be able to take advantage of the that cam, if you have the stock short block (stock piston and Rods). If you rev the short block to 5500rpm it will grenade within a short time, if keep the rev down you won't be in the power band of the cam.
Syonara
Drop the idea of that cam--Get the 50lbs inj.and a converter 2600,2800,3000stall. and a 3bar map sensor! Unless you want to build the motor.
Syonara
With the mods listed on ur tag-- I rec. the inj. converter, 3bar and a chip...that should kick u into the 12's bro.
jwaller
Evil Genius/SyTy Guru
the_erickee said:
Who do I get a hold of to make my chip? What type of performance gains should I expect?
I can do the nessassery chip mods for you.
I guess i will go w/ the 50# injectors, 2800 stall TCS convertor, 3bar map, and ultimate v7. Ill hit the twelves w/ that setup on the stock turbo?
ty1435_4.3
Shes almost ready
I have a T-72 now. I want to put vortecs in. But I want to change the set up to a 4bbl intake modded to fuel injection and a 90deg bend with a throtle body. I have the 50lbers a v6 ultimmate and a built short block. Any idea on how to and what parts I will need?? TIA
SY2932
Administrator
From http://69.9.37.28/~sytynet/forums/showthread.php?t=25579&page=3 :
12.5 @106 with stock motor & turbo, built trans, 3K stall converter, lock up switch, engine tie down, 30 psi on all four tires, xylene plus 93 octane blend and Ultimate chip set to T2 20 psi. Hope to touch 11's with a <<<PT-70 and drag radials later this year. Then my mod days will be over...
In addition to everything listed above, I have all the "safety" mods (Walbro fuel pump, adjustable fuel pressure regulator, 3/4 heater hose IC lines, etc). I'm still running stock injectors too BTW.
