blk00z28
Forced to by choice
It was talked a lot a few months back about doing this. There were a few that chimed in to help out and say where you got the fittings from for the o-ring on the stock sending unit. There were some things I probably could have done different. Like, use one of those super $$ high flow fuel filters from Jegs, or Summit. BUT, the main reason why I didn't do that is when I'm doing a fuel filter change, I can drive 10 mins to the auto parts store and get a stock replacement. Rather then wait 3 days, and a bunch more money waiting on the replacement high flow filter from one of the online stores to get shipped to my house.
***Note that this is NOT for stock fuel rails. If I had a set of fuel rails handy I would spec the fittings out, but I sold that thing a while ago.
Now, because I did this. It requires some odd fittings to be used. Mainly going from a o-ring mm fitting to a -8. I believe RPM sells an o-ring 16mm x 1.5 to -8. I could not find one anywhere online. Summit/Jegs, and a few other online stores did however sell it to -6. Which means you'll have to use a enducer from -6 to -8 if you don't get the actuall 16mm x 1.5 to -8(and -6 for the return line.)
I used a company called RedHorse Performance(http://www.redhorsedirect.com/catalog/) for all of my normal fittings and hose. All of my fittings, and hose are in black with the exception of the o-ring, and enducer fittings that do not come in anything else then blue or chrome/alum finish. Some of there stuff was a little cheaper then other places. Some if its about the same or a little more. But the quality of the fittings omg are nice. The enducers, and those o-ring fittings I searched the web for because at the time Summit did not have more then 1 in stock. (I believe they do now.)
The measurements I used came off the stock hard lines. I haven't got around to putting the tank back in the truck yet because I'm still in the air as how I'm going to do the double pumper set up, or better yet. How much I'm actually going to spend on it..
This is a list of what I've bought for this job. (I'm pretty sure I've broken down the fittings required to do this correctly. I ordered a lot of fittings to do this, my turbo coolant lines, and the valve cover breather lines so there might be one or two things missing, or incorrect. But its pretty simple to figure out if I leave off a hose end that it needs one..)
Feed line hose:
32" of -8 from the stock sending unit to the inlet port in the fuel filter.
82" of -8 from the outlet port of the fuel filter to the fuel rail. (my pressure gauge unit I'm screwing into the inlet port of the filter to save some fittings, this makes it easier, all I have to do is run longer wiring to it.)
8-10" of -8 from one fuel rail to the other(I haven't done this yet, I have enough hose just waiting till I'm closer to dropping the motor in.)
My FPR will be screwed onto the back of the pass rail, so no more hose will be used as of right now.
Return line hose:
126" of -6 from the stock sending unit return fitting to the FPR.
Fittings and break down of how things go together:
Feed from stock sending unit:
-6 male to 16mm x 1.5 to -6
-6 female to -8 male expander
-8 straight hose end
-8 hose
----------fuel filter-----------
-8 hose
-8 to /npt to fuel rail.
Drivers rail:
-8 to /npt out from rail
-8 hose
Pass rail:
-8 to -8 coupler
-8 to -8 union into fpr
Return from stock sending unit:
-6 male to 14mm x 1.5 to -6
-6 straight hose end
-6 hose
-6 hose end(either 90*, straight, or another angle)
-6 male to -6 male reducer into fpr
My over all cost for fittings, and hose to do this was slightly over $400. Add a fpr, and you're over $500.
Picture of the hose with ends and a few of the 16mm x 1.5 to -6, and enducers from -6 to -8.
Feed line hose:
Return line hose:
-8 hose
-8 hose
Drivers rail:
-8 hose
Pass rail:
-8 to -8 coupler
-6 hose
