Computer Help....ALDL plug and Datamaster Cable
EDIT:
OK, I got the correct pins and have been using them all along.
Now I need to get the computer to use the port. It HAS located the cable on COM 3 but still fails to connect. If I check it again it fails to locate the cable.
Forgive me for being stupid.....:oops:
I can't find which pins to use on the ALDL plug for the Datamaster Cables. :rant:
I found this thread... suggesting "A" & "M" but no dice.
http://www.syty.net/forums/showthread.php?t=35786&highlight=aldl+datamaster
I am using Tuner Pro RT and my computer recognizes the plug but doesn't transfer data.
I figure i was using the wrong pins on the ALDL.
Can someone please clue me in since search isn't helping me any?
TIA:tup:
gmcturbo
Re: ALDL plug and Datamaster Cable
bottom right
mmp142965
say it like you spell it!
Don, you definitly need to use A and M, The ground is A and the data port is M. I finally got my cable to work and those are the pins I used. I had trouble with my USB adapter and after I bought the Belkin adapter suggested in the datamaster users manual, everything was peachy.
gmcturbo
m, sorry for the confusion- have you tried datamaster? i had trouble with tunerpro rt also.
Thanks guys, I'm headin' out to give it shot again. I was a little short on time yesterday so I didn't have a chance to go through the software. I'll let you know how it went now that I know for sure which pins to use.
In the settings where you set com port hit the test aldl cable. Does it show up?
Sometimes.... The Ostrich is on COM4 and it locates the cable on COM3 but only once when I first load the program. If I check again after that it can't find it.
I know a little bit about computers and such but this really has me stumped.
Re: Computer Help....ALDL plug and Datamaster Cable
I got it working... I just unplugged the Ostrich (Emulator) and the 9 poin worked perfect. It seems that eventhough they were directed to use different COMports, they were still fighting over the same one. i didn't even get the adapter yet. (not Belkin, I'll let you know if it works)
