computer
C
chuck
Guest
i just resently rebuilt my engine in my syclone. when it is running the vacum pressure drops and the fuel pressure takes off. what can i do to fix it
V6 Kompressor
Look for vacuum leaks, use carb cleaner (Be careful,the stuff is really flamable) to spray around the intake mounting gasket points, throttle body, ect. listen for an increase in rpm... did you put on new plastic vacuum hose? The stuff gets brittle with heat and age and will break half into, so you don't see the crack. Did you install a larger camshaft??? Valve lash correct? So many things can cause this, you need to make a list, and check/change only one thing at a time. Do you have acces to a scan-tool??? And also, do a search on this board for members with past problems and solutions. Oh, yes..When the vacuum does fall, the fuel pressure regulator is supposed to add more pressure...
just a 6
R.I.P MyClone
Did you time it right on the mark? (timing chain) Most of the times you start a rebuild engine and the vacuum is low is b/c the timing is off one teeth or so.
