Coolant overflow tank #?
jwaller
Evil Genius/SyTy Guru
Re: Coolant overflow tank #?
it's the same as a std S-series. you have to drill the hole for the IC yourself if you still use the stock IC.
15560958 – CAC/Radiator Overflow Reservoir
VermontTy
Support Our Troops
I do need to still use the stock IC, so just drill a hole in the top of the tank and feed the overflow line from the IC into the hole? Thanks John.
jwaller
no the stock bottle has a hole in the side and in the rear and has it's own special fitting that runs to a hose inside the bottle, but the system doesnt work and you have to keep topping off the ic anyway. when I had the stock upper I just deleted the line and used a std bottle.
VermontTy
Support Our Troops
Got it. Same clear plastic barb threads into the rear of the tank and goes to the IC. Thanks again John.
