coolant return line delete
warmpancakes
ok new turbo isnt water cooled and im finding the coolant fitting in block is a bitch to get to, any tricks? only good thing is front clip is off truck so I have a little more access DP and turbo will be out too
TNPhoon
1of28
Re: coolant return line delete
I actually NEED that fitting. I didn't take it off and machine shop ditched mine when they did the block.
I can access it from going up along the frame right on up by the motor mount. Now granted...I haven't attempted to get a wrench up there yet, it looks like it's going to be beyond a bitch to tighten.
TNPhoon
1of28
Hey Ken,
Were you able to get that fitting out?
Curious as to the block side size.
Quickstop [UK]
Combating adversyty.
It's a 1/2" NPT plug you could use to plug it.. as for the original, don't know..
I use an NPT - -6AN fitting now.
I believe it's 3/8 not 1/2 pipe. Don't use an end wrench, you'll ruin the fitting. You must use a box, or, if the line is off maybe a socket.
s10blaza
BOOSTED
I've found it's really easy to get to by taking the starter out. Crow's foot makes it even easier
