coolant sensor with ATR headers?
jjorgensen52
NHSTE - I'm the only one!
It appears, after installing my atr headers, that both coolant temperature sensor and another unknown port in my new vortecs are partly covered. I'm capping the one as it has no function, but on the oher head how do I get the temp sensor in? Cut the header flange?
MikeRenz
not stock
Re: coolant sensor with ATR headers?
usually people just notch the flang. Can you use the port on the passenger side head instead? Or is that covered also
jjorgensen52
both covered. I figured notching was all it would want. Last little bits of assembly going on now :tup: (but my dyno time has been bumped to next monday :tdown: )
MikeRenz
not stock
wel that'll give you plenty of time to cut a nice perfect circle or dremel it to be like 1mm around the sensor
jjorgensen52
MikeRenz said:
does the knock sensor enjoy hot water?
I need to find a plug for that other port. Anybody happen to know the thread / diameter of the sensor (seemed like it was a metric to me but it wasn't anything normal that I could find :( )
MikeRenz
not stock
my ty came with a broken temp sensor being used as a plug :lol: Just take the sensor to autozone/advanced auto and get yourself the right sized plug. Its a common size.
jjorgensen52
turns out to be a NPT fitting :roll: ... anyway just need to find a good flush plug for it and I'll be all set
TurboJunk
questionable
on LT1 cars the knock sensor is in the side of the block in the water jacks, my CPI 4.3 also had it there. im just asking!!!!
MikeRenz
not stock
i was just asking also. Some sensors aren't meant for water...wasn't sure if knock sensor would be one. Especially since sound travels through water differently than through air.
TurboJunk
questionable
oh ok sorry.... from what ive learned they can and sound travels better in water ( might not be a great think but it better thn getting knock from the trans.
Also you seem to be my late night question answerer... respond in my push rod post Renz
MikeRenz
not stock
yea and depending on the sensitivity of the knock sensor, water sounds may be too much.
